We were pretty excited to test out bloom filters, as on a large volume, our slowest part would be pulling chunks from the GCS. However, query performance drops significantly when filtering is enabled, and I can pinpoint why…
Here is the comparison when using a structured metadata field and when blooms are in use (key=value matching added):
Results of: sum by (ctxt_msg)(count_over_time({service_name="api",method=~"v2_website"} |= "server state check" [$__auto]))
Stats
Total request time 11.3 s
Number of queries 1
Total number rows 1845
Data source stats
Summary: total bytes processed 20.0 GB
Summary: exec time 8.02 s
Results of: sum by (ctxt_msg)(count_over_time({service_name="api",method=~"v2_website"} |= "server state check" | ctxt_msg="<NULL>"[$__auto]))
Stats
Total request time 3.43 mins
Number of queries 1
Total number rows 1443
Data source stats
Summary: total bytes processed 8.78 GB
Summary: exec time 3.37 mins
Bloom settings are exactly as mentioned in the documentation:
loki:
bloom_build:
enabled: true
planner:
planning_interval: 6h
bloom_gateway:
enabled: true
limits_config:
bloom_creation_enabled: true
bloom_split_series_keyspace_by: 1024
bloom_gateway_enable_filtering: false
Running 10 bloom gateways and 15 index gateways, and I see that most of the time is spent on chunk_refs_fetch_time (indexing)
total_time_s 11.512756889
chunk_refs_fetch_time 11.441082839s
index_bloom_filter_ratio 0.00
index_post_bloom_filter_chunks 11
index_total_chunks 11
index_used_bloom_filters true
At this point, I am lost and disabled bloom filtering altogether, but hopefully the community will come to the rescue!
