I’m trying to configure a simple query with query builer and I don’t find the time filter setting. Am i missing something? Also I cannot apply a group by macro.
Datasource: Postgresql
Version is 9.4.0, the same happens on 9.3.6.
I just upgraded to the latest Grafana release and now I’m facing the same issue.
Before the upgrade, the querybuilder was totally different.
I also can’t find an entry in the releasenotes that this is changed (Or I missed it…)
Does anyone know what exactly happened to the “old” querybuilder?
Regards,
Marco
(I also use timescaledb/postgres)
I just found this:
I can’t also manually find a table by its schema like in the past, e.g. schema.table.
