New builder Postgresql
Dear all
How you can use windows function with the new postgresql builder ?
How you can indicate te timefilter ?
in advance thanks
which windows function are you referring to specifically?
I am using a lot the mooving average function.
This new builder is very strange, we do not find back all the options of the previous one. I am worried that I will have to use the code only.
or use stored procedures which will never require change. builder is just a helper.
yes , builder is just an helper , but it is strange that it worse than the previous version.
Without the builder , it is more complicated for me.
for exemple here , I do not understood why the min and max are not done correctly on all the period.
my code
SELECT
$__timeGroupAlias(mois,8760h),
min(dc) AS “min”
FROM insee_dc_naissance
GROUP BY 1
ORDER BY 1
You do not have max in your query
Your issue is really not grafana but querying issue.
I have three query : one for the value , one for the yearsly min of the value , one for the yearsly max of the value.
SELECT
mois AS “time”,
dc AS “décés”
SELECT
max(dc) AS “max”
GROUP BY 1
ORDER BY 1
SELECT
min(dc) AS “min”
GROUP BY 1
ORDER BY 1
and I do not understood why the calculation show that ?
could you help me to find what is wrong on my query ?
