I saved the data using influxdb as below, and if you check it using “explore” by Grafana, it is as follows.
However, the “data” of the “Inspector” has higher precision as shown below.
I don’t know why the queried data shows only two decimal places.
welcome to the
community @kihwan01!
I haven’t noticed this before, but I see the same thing with our test datasource in that view. It looks like explore rounds to one decimal place.
If you create a query in the timeseries panel, there is a configuration option in the panel under standard options where you can adjust the number of decimal places to show in your panel:
Thanks for your reply. That’s perfect!
