I have a provisioned dashboard that correctly resides in a folder from which other dashboards are picked up. However, this one dashboard doesn’t appear in the Web UI of Grafana and also no errors are logged.
I took a look at the sqlite file for our installation and what I see is that the dashboard is contained in the dashboard table:
select id, title, created, updated, updated_by, is_folder from dashboard;
12|Database Consistency Alerting|2020-03-10 08:00:58|2020-03-29 12:06:23|-1|0
and also in the dashboard_provisioning table:
select * from dashboard_provisioning;
2|3|infrastructure|/var/lib/grafana/dashboards/infrastructure/node-exporter.json|1583827235|ce2848adaf6ab9abd474a8b3941cbdcc
201|12|sidecarProvider|/tmp/dashboards/db-consistency-dashboard.json|1585483583|642c528b06ce89d2df48ac5cd2602d31
202|5|sidecarProvider|/tmp/dashboards/api-events-dashboard.json|1585483583|b97de6a40e76b94f730f3a1850a67dc7
Any idea what could be causing this behavior?
