Provision dynamic dashboard grafana 13
  • What Grafana version and what operating system are you using? : 13.0.1
  • What are you trying to achieve? Provision dynamic dashboard
  • What happened? Parsing error on dashboard load
  • What did you expect to happen? Load dashboard normally
  • Can you copy/paste the configuration(s) that you are having problems with? I am using AutoGridLayout which is causing the problem. As soon as I make it GridLayout it works. But ‘Auto’ doesn’t
  • Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were:
    Failed to load dashboard
    Cannot convert non-GridLayout layout to v1
  • Did you follow any online instructions? If so, what is the URL? I could not find proper instructions on how to provision a dynamic panel. I can use it from the UI but I am unable to provision it.
    Since ‘show/hide’ panel option works only with AutoGridLayout i am not sure how can I use it if AutoGridLayout is not working with provisioned grafana dashboard.
Sure I did read the provisioning doc and was able to use the kubernetes format to provision dashboard but I am still missing the details instructions on how to provision a dashboard with autoGrid layout so that one can take advantage of the show/hide panel features.
