Propagate app plugin configuration to data sources
Hi, I’m using the new plugin tools to create an app plugin that bundles some data sources together: Nested Plugins | Grafana Plugin Tools
I see that the app plugin itself can have some configuration options (example). Is there a way to access those options from the nested data sources? It would be nice to, for example, only have to configure a URL and API key in one place.
