I would like to know if exist agent promtail for Solarios OS.
I want to use Grafana Loki to obtain logs from Solaris servers, but the web "https://github.com/grafana/loki/releases/” doesn’t show nothing related with solaris.
Promtail agent exists for Solaris servers?
Hi @monicat590
There are no binaries or planned support for Solaris, unfortunately.
You might try compiling the binaries yourself; I believe Go supports Solaris.
If you’d like to try this, we can potentially provide you with some guidance - although I don’t think we have anyone with Solaris expertise.
Hi @anon74857911,
Thank you for your answer. I finally won’t need the agent for those servers
Regards
When I’m trying to build promtail in solaris os with sun4v64 architecture I’m getting below error:
-bash-5.2$ go build main.go
runtime: lfstack.push invalid packing: node=0x7fe3ac6ae9100 cnt=0x1 packed=0xfe3ac6ae91000001 → node=0xfffffe3ac6ae9100
fatal error: lfstack.push
runtime stack:
runtime_mstart
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/runtime/proc.c:606
goroutine 35 [running]:
cmd/go/internal/imports.keys
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/imports/scan.go:103
cmd/go/internal/imports.scanFiles
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/imports/scan.go:95
cmd_1go_1internal_1imports.ScanDir
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/imports/scan.go:40
cmd/go/internal/modload.scanDir
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/modload/load.go:2096
cmd_1go_1internal_1modload.loader.load
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/modload/load.go:1725
cmd/go/internal/modload.loader.pkg…func2
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/modload/load.go:1509
cmd/go/internal/par.Queue.Add…func1
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/par/queue.go:58
created by cmd_1go_1internal_1par.Queue.Add
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/par/queue.go:56 +0x174
goroutine 1 [semacquire]:
sync.runtime__SemacquireMutex
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/runtime/sema.go:71
sync.Mutex.lockSlow
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/sync/mutex.go:162
sync.Mutex.Lock
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/sync/mutex.go:81
sync.Map.LoadOrStore
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/sync/map.go:210
cmd_1go_1internal_1par.Cache.Do
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/par/work.go:122
cmd_1go_1internal_1modload.loader.pkg
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/modload/load.go:1503
cmd/go/internal/modload.loadFromRoots
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/modload/load.go:1080
cmd_1go_1internal_1modload.ImportFromFiles
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/modload/load.go:704
cmd_1go_1internal_1load.GoFilesPackage
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/load/pkg.go:2931
cmd_1go_1internal_1load.PackagesAndErrors
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/load/pkg.go:2679
cmd/go/internal/work.runBuild
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/work/build.go:382
main.invoke
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/gotools/…/libgo/go/cmd/go/main.go:221
main.main
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/gotools/…/libgo/go/cmd/go/main.go:178
goroutine 49 [semacquire]:
sync.Mutex.lockSlow
sync.Mutex.Lock
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/modload/load.go:1743
goroutine 30 [runnable]:
cmd_1go_1internal_1modload.MainModuleSet.ModRoot
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/modload/init.go:153
cmd/go/internal/modload.importFromModules
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/modload/import.go:300
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/modload/load.go:1695
goroutine 31 [runnable]:
goroutine 11 [runnable]:
sync.Mutex.lockSlow
sync.Mutex.Lock
goroutine 42 [semacquire]:
bufio.NewReaderSize
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/bufio/bufio.go:57
bufio.NewReader
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/bufio/bufio.go:63
cmd_1go_1internal_1imports.ReadImports
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/imports/read.go:230
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/imports/scan.go:58
goroutine 12 [runnable]:
cmd_1go_1internal_1imports.importReader.readString
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/imports/read.go:187
cmd_1go_1internal_1imports.importReader.readImport
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/imports/read.go:212
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/imports/read.go:239
goroutine 29 [runnable]:
syscall.Exitsyscall
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/runtime/proc.go:3741
syscall.Lstat
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/build/sparcv9/sparcv9-sun-solaris2.11/libgo/libcalls.go:2028
os.lstatNolog…func1
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/os/stat_unix.go:45
os.ignoringEINTR
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/os/file_posix.go:245
os.lstatNolog
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/os/stat_unix.go:44
os.Lstat
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/os/stat.go:22
os.File.readdir
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/os/dir_gccgo.go:126
os.File.Readdir
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/os/dir.go:41
io_1ioutil.ReadDir
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/io/ioutil/ioutil.go:63
cmd/go/internal/fsys.readDir
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/fsys/fsys.go:246
cmd_1go_1internal_1fsys.ReadDir
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/fsys/fsys.go:270
cmd_1go_1internal_1fsys.IsDirWithGoFiles
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/fsys/fsys.go:363
cmd/go/internal/modload.dirInModule…func2
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/modload/import.go:653
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/par/work.go:128
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/modload/import.go:652
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/modload/import.go:302
goroutine 13 [semacquire]:
sync.Mutex.lockSlow
sync.Mutex.Lock
goroutine 23 [runnable]:
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/modload/load.go:1498
goroutine 14 [semacquire]:
sync.Mutex.lockSlow
sync.Mutex.Lock
sync.Map.Load
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/sync/map.go:107
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/par/work.go:120
goroutine 32 [runnable]:
goroutine 50 [semacquire]:
bufio.NewReaderSize
bufio.NewReader
goroutine 51 [semacquire]:
sync.Mutex.lockSlow
sync.Mutex.Lock
goroutine 15 [runnable]:
syscall.Exitsyscall
syscall.fcntl
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/build/sparcv9/sparcv9-sun-solaris2.11/libgo/libcalls.go:758
syscall.SetNonblock
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/syscall/exec_unix.go:173
os.newFile
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/os/file_unix.go:181
os.openFileNolog
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/os/file_unix.go:254
os.OpenFile
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/os/file.go:338
cmd_1go_1internal_1fsys.OpenFile
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/fsys/fsys.go:357
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/fsys/fsys.go:330
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/imports/scan.go:53
goroutine 129 [runnable]:
goroutine 52 [runnable]:
goroutine 68 [semacquire]:
sync.Mutex.lockSlow
sync.Mutex.Lock
goroutine 82 [semacquire]:
cmd_1go_1internal_1imports.importReader.readByte
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/imports/read.go:60
cmd_1go_1internal_1imports.importReader.peekByte
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/imports/read.go:106
cmd_1go_1internal_1imports.importReader.readKeyword
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/imports/read.go:139
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/imports/read.go:232
goroutine 83 [runnable]:
syscall.Exitsyscall
syscall.Open
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/build/sparcv9/sparcv9-sun-solaris2.11/libgo/libcalls.go:2075
os.openFileNolog
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/os/file_unix.go:230
os.OpenFile
goroutine 69 [runnable]:
syscall.Exitsyscall
syscall.Open
os.openFileNolog
os.OpenFile
goroutine 70 [semacquire]:
sync.Mutex.lockSlow
sync.Mutex.Lock
sync.Map.Load
goroutine 130 [semacquire]:
strings.Builder.grow
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/strings/builder.go:67
strings.Builder.Grow
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/strings/builder.go:81
strings.Join
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/strings/strings.go:438
path_1filepath.join
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/path/filepath/path_unix.go:45
path_1filepath.Join
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/path/filepath/path.go:213
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/modload/import.go:616
/builds/11.4-SRU/11.4.60.0.1.151.1/components/gcc12/gcc-12.2.0/libgo/go/cmd/go/internal/modload/import.go:301
goroutine 145 [runnable]:
goroutine 161 [runnable]:
Can you guys please provide some guidance?
