Hi All,
We have metrics which contains time-series records. The date value/timestamp is stored as label in the metrics. Our requirement is to create a line chart, where the date (label) to be used in x-axis and metrics value in y-axis. I have already tried different options like
- Added two labels - one long value of timestamp and another string value(mm-dd-yyyy) in the metric.
- I had transformed the date value (timestamp long value) to numeric.
- Then added that column to x-axis.
- But the chart is not showing any line.
- Also the question is can I show the string value of date in x axis(although in the background it uses the number value).
Example:
sample_time_series{some unique labels, date=“12-12-2023”, dateLongValue=“17837264838”} - 10
sample_time_series{some unique labels, date=“12-13-2023”, dateLongValue=“17947264844”} - 12
Line chart should a line from value 10 to 12 with x axis as 12-12-2023 and 12-13-2023.
Any assistance would be highly appreciated.
