Hello, just throwing a bottle in the ocean. I’m maintainer of prometheus-community/monaco-promql and I was wondering if I should spend more time updating it more regularly, is it used and so on, when I just noticed that
- first you are using it, cool! Never seen an issue coming from you over there, don’t hesitate!
- second you copy-pasted most of our code into Grafana codebase. grafana/packages/grafana-prometheus/src/components/monaco-query-field/promql.ts at main · grafana/grafana · GitHub less cool!
I have absolutely no problem with the fact that you copy paste it. The licence allow it.
I’m just wondering if there is an issue that I can fix to allow you to just import it as a lib ? Or some stuff that I could change to be configurable. I believe you’d benefit from maintenance updates.If somebody there is expert in integration of languages into your monaco-editor ecosystem, I’d be glad to have a talk!
Cheers
