Hi guys,
Ive followed the build from source guide, Ive got grafana to compile and run but when I then try to install and run bra I get “No command ‘bra’ found”.
Here’s the console message:
root@james-MS-7C02:~/grafana# go get github.com/unknwon/bra
go: finding gopkg.in/fsnotify/fsnotify.v1 v1.4.7
go: finding golang.org/x/sys v0.0.0-20191020152052-9984515f0562
root@james-MS-7C02:~/grafana# bra run
No command ‘bra’ found, did you mean:
Command ‘ra’ from package ‘argus-client’ (universe)
Command ‘bar’ from package ‘bar’ (universe)
Command ‘br’ from package ‘bottlerocket’ (universe)
Command ‘bwa’ from package ‘bwa’ (universe)
Command ‘brag’ from package ‘brag’ (universe)
Command ‘bro’ from package ‘bro’ (universe)
Command ‘ara’ from package ‘ara’ (universe)
bra: command not found
Im almost there, this is the last thing thats causing me an issue, PLEASE help Lol.
Cheers
James
