Problem with width of stacked bars in bar chart when only 1 value
Hi, I’ve a strnge behavior with stacked values on bar chart when there is only one value :
    10.3.1
    Display a bar graph with stacked values
    I use bar graph mode, stack values to normal, bar width to 0.7
  • What happened?
    When there is multiple values to display, bar is stacked correctly, and have the right width.
    If I mode width cursor, it works.
If I’ve got only one value, width cursor doesn’t works anymore and parameter is no taken into account, width is 1.
    Be able to keep width even there is no values to stack (only 1 value)
Encountered the same problem. No solution yet?
