Problem with oauth2 integration between grafana and keycloak
    • grafana operator, grafana version 12.2.1
    • authorize to grafana using keycloak. Log in with user which contains role mapped from token
    • values.yaml for grafana.ini
    • version: 12.2.1
      config:
    auth:
    disable_login_form: “false”
    auth.generic_oauth:
    enabled: “true”
    allow_sign_up: “true”
    client_id: ${AUTH_CLIENT_ID}
    client_secret: ${AUTH_CLIENT_SECRET}
    scopes: “openid email profile offline_access roles”
    email_attribute_path: email
    login_attribute_path: username
    name_attribute_path: full_name
    groups_attribute_path: groups
    auth_url: <auth_url>
    token_url: <token_url>
    api_url: <api_url>
    role_attribute_path: “contains(resource_access.grafana-oauth.roles\[*\], ‘admin’) && ‘Admin’ || contains(resource_access.grafana-oauth.roles\[*\], ‘editor’) && ‘Editor’ || ‘Viewer’”
  • What happened?
    • logged user always gets viewer role
    • log in to grafana using keycloak sso with correct role
  • Can you copy/paste the configuration(s) that you are having problems with?Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
    • no errors in info or debug mode
Point of debug logs is to see what was received in the id/access token and compare it with the config.
I would say at least hyphen in the jmespath (grafana-oauth) is a problem. Find how to properly escape/write it so it will be interpreted as correct key. Test it on https://jmespath.org/ Or just simple configure keycloak client so it doesn’t contain hyphen in the claim.
Yeah you were right about that, thanks for help. I think this should be pointed in official documentation otherwise example should be changed to avoid confusion.
