I have a problem with the conversion of custom timestamps. I use a regular expression to parse the logs and append three labels and a format line. Once all programs are started, I see in Loki all labels parsed correctly, but no data. A query over a label from the list also returns no results: “No data”.
To Reproduce: I start the programms with docker-compose:
version: “3”
networks:
loki:
services:
loki:
image: grafana/loki:2.2.0
ports:
- “3100:3100”
volumes: - ./Loki/loki-config.yml://etc/loki/local-config.yaml
command: -config.file=/etc/loki/local-config.yaml
networks: - loki
promtail:
image: grafana/promtail:2.2.0
ports:
- “9080:9080”
volumes: - /var/log:/var/log
- ./logs:/var/log/dav
- ./Promtail/promtail_dav.yml:/etc/promtail/config.yml
command: -config.file=/etc/promtail/config.yml
networks: - loki
grafana:
image: grafana/grafana:latest
ports:
- “3000:3000”
networks: - loki
volumes: - grafana-loki-storage:/var/lib/grafana
volumes:
external: true
Expected behavior:
Timestamps are taken from logs and displayed in Loki as entry time instead of the time of receipt of logs.
Promtail config:
Log Example:
#170 18.02.2021 06:57:03,862:+0200 (TID:000001) … KONFIG : ConfigurationApp.de.bsvrz.puk.config.configFile.fileaccess.ConfigFileHeaderInfo
#171 18.02.2021 06:57:04,865:+0200 (TID:000001) ---------------------- INFO : ConfigurationApp.de.bsvrz.puk.config.configFile.fileaccess.ConfigAreaFile Laden der Konfigurationsdatei: /bet/vba_a81/kernsoftware-3.8.0/kv.aoe.bw.uz.A81.sba_stgt/konfiguration/kb.objekte.Zlt.A81.sba_stgt.config
Screenshot after start:
Thanks a lot for your help!
