Problem setting up Application monitoring in Grafana Cloud
❯ helm list -n infra
NAME                  	NAMESPACE	REVISION	UPDATED                                	STATUS  	CHART                	APP VERSION
grafana-k8s-monitoring	infra    	1       	2025-03-15 22:06:44.047244144 +0400 +04	deployed	k8s-monitoring-2.0.18	2.0.18
    I want to enable back application monitoring after it was shut down because of the new pricing model
    with the following values.yaml, installing the latest version of the helm chart
  • What happened?
    The chart was deployed successfully, I can see application metrics, logs and spans in the UI, BUT on the application monitoring page I still get the message that I have to enable the applicationObservability even though it is enabled in the values file as the instruction requires Application Observability host-hours pricing | Grafana Cloud documentation. Here is the metrics status page
    Application observability working
clusterMetrics:
  enabled: true
  opencost:
    enabled: true
    metricsSource: grafana-cloud-metrics
    opencost:
      exporter:
        defaultClusterId: do-prod
      prometheus:
        existingSecretName: grafana-cloud-metrics-grafana-k8s-monitoring
        external:
          url: https://prometheus-prod-24-prod-eu-west-2.grafana.net/api/prom
  kepler:
    enabled: true
prometheusOperatorObjects:
  enabled: true
clusterEvents:
  enabled: true
podLogs:
  enabled: true
applicationObservability:
  enabled: true
  receivers:
    otlp:
      grpc:
        enabled: true
        port: 4317
      http:
        enabled: true
        port: 4318
    zipkin:
      enabled: true
      port: 9411
  connectors:
    grafanaCloudMetrics:
      enabled: true
integrations:
  alloy:
    instances:
      - name: alloy
        labelSelectors:
          app.kubernetes.io/name:
            - alloy-metrics
            - alloy-singleton
            - alloy-logs
            - alloy-receiver
alloy-metrics:
  enabled: true
alloy-singleton:
  enabled: true
alloy-logs:
  enabled: true
alloy-receiver:
  enabled: true
  alloy:
    extraPorts:
      - name: otlp-grpc
        port: 4317
        targetPort: 4317
        protocol: TCP
      - name: otlp-http
        port: 4318
        targetPort: 4318
        protocol: TCP
      - name: zipkin
        port: 9411
        targetPort: 9411
        protocol: TCP
Were you able to get it to work? As I’m having same issue ATM?
Hi Knoura,
Yes, we can figure out , We have team of 20 people working various Grafana projects, Let us know If you are ready to give us work as paid.
Regards,
Shanker Agarwal
Why not for free here on the community forum?
