- Grafana Cloud integrated with a Kubernetes cluster on Digital Ocean.
- Application stack: Node.js.
- Display application logs in the Application Observability dashboard, grouped by service.
- Currently, logs only appear in the Logs UI, separated by instance, but they do not appear in the correct service view within the Application Observability panel.
- Installed grafana-k8s-monitoring following the official documentation.
- Enabled
podLogs, and logs appear correctly in the Logs UI. - My application uses @opentelemetry/api and @opentelemetry/auto-instrumentations-node for metrics, traces, and logs.
- Metrics and traces are correctly registered and displayed in the Grafana dashboard, but logs are not shown under the service in Application Observability.
What happened?
- Application logs are not displayed in the Application Observability view but are correctly available in the Logs UI, filtered by instance.
- Metrics and traces appear correctly in the dashboard.
- Expected logs to be associated correctly with the service and visible in the Application Observability dashboard alongside metrics and traces, without needing to filter by instance.
Here is my values.yaml configuration:
yaml
CopiarEditar
destinations:
- name: grafana-cloud-metrics
type: prometheus
url: https://prometheus-prod-56-prod-us-east-2.grafana.net/api/prom/push
auth:
type: basic
username: "XXXXX"
password: XXXXX
- name: grafana-cloud-logs
type: loki
url: https://logs-prod-036.grafana.net/loki/api/v1/push
auth:
type: basic
username: "XXXX"
password: XXXXX
- name: grafana-cloud-traces
type: otlp
url: https://tempo-prod-26-prod-us-east-2.grafana.net:443
protocol: grpc
auth:
type: basic
username: "XXXX"
password: XXXXX
metrics:
enabled: false
logs:
enabled: false
traces:
enabled: true
- name: grafana-cloud-profiles
type: pyroscope
url: https://profiles-prod-001.grafana.net:443
auth:
type: basic
username: "XXXX"
password: XXXXX
podLogs:
enabled: true
namespaces:
- apps
applicationObservability:
enabled: true
receivers:
otlp:
grpc:
enabled: true
port: 4317
http:
enabled: true
port: 4318
zipkin:
enabled: true
port: 9411
connectors:
grafanaCloudMetrics:
enabled: true
autoInstrumentation:
enabled: true
- No errors appear in the Grafana UI.
- Logs appear correctly in Loki, but they are not grouped under Application Observability Dashboard.
- Followed the grafana-k8s-monitoring documentation: https://grafana.com/docs/kubernetes-monitoring/
Question
Is there any additional configuration needed to ensure logs are correctly grouped by service in the Application Observability Dashboard?
