Private probes' ip address
Just wondering what the private probe’s ip address would be, and can that be configured personally
Hi @eb1932261545 - the Private Probe IP address will be configured according to whatever IP addresses/ranges you may have for your environment! This allows you to use your own custom probes for regions where Grafana may not have any available. You’ll want to check your hosting provider and/or OS for how to manage private IP addresses/ranges.
