Inspect-query does not show query when causing syntax error, neither log level debug
Using Grafana 7.3.1 with Postgresql. I really love the inspect - query function because I can right away post it in pgadmin. However this works only for me if the syntax of the query is correct.
Then I can use it for data problems, e.g. why is the answer empty?
However, if the syntax is not correct, error like: pq: syntax error with postgres at or near the inspect-query function just shows the same error message as a tree.
That means, at the point that it would be most helpful, I do not get the query.
Also augmented log level to DEBUG. There is not even an error shown, just outputs like Successfully connected to Postgres.
Is there any easy way to get more information out of Grafana?
If I do not find it out by simply looking deeper into the raw request (40 lines, 2691 chars), I will either look into postgres or into tracing.
