Hello dear Grafana community !
I am running grafana locally in a docker container, using the official image grafana/grafana:8.4.1. My host machine is a Ubuntu 21.10. I also have a postgres (13) database in another container to store the grafana data.
I have build a custom datasource and custom plugin to interact with an API that I have developed. Everything is working well, I am able to create and save my dashboards. I am able to see them in the database, in the “dashboard” table. I am also able to correctly edit my dashboards using my plugin. However, when I want to change the time range using the Grafana’s time range picker, it does change but it is not saved in the database.
Is it the intended behavior ? I saw in the docs the following “Time settings are saved on a per-dashboard basis.” which I think means it should indeed be saved.
Is it something configurable ? Or is there a fairly easy way to customize the action behind the dashboard “save” button?
Thank you for your lights !
