I want to populate a template variable dropdown from an Elasticsearch query that gives me a logarithmic range of numbers from a number field in the index.
The idea is I want to have an Execution Times dropdown that has values like 1ms, 2ms, 4ms, 8ms … etc with the minimum and maximum drive by the data in my index.
Even better is if there is a way to make the field give me a range so I can plugin the value to a query ex. executionTime:$RangeValue (would turn into [16 TO 32]) instead of what I assume I will need to to which is have two seperate dropdowns for a min value and a max value.
