Feature : Elasticsearch templated Metric type
Have you ever think about “templating” metrics (max, average…)
The point is I have for instance a panel displaying CPU usage, RAM usage, IO usage etc.
I currently display the “Max” value on the time interval.
I would like to be able to have a template variable to switch between the metric type (Max, Average…)
That way, I won’t need to duplicate all my queries to change the type.
What do you think about it ?
Regards,
You should open a feature request for this if it doesn’t already exist.
