Using python I ingest system metrics into ES (example below).
Now, I’d like to use the templating to display only the needed information, let’s say the “user” and “system” values.
"_index": "system-2018-02-26",
"_type": "system",
"_id": "QS9l0WEBwt1FT8MlvRO6",
"_version": 1,
"_score": null,
"_source": {
"user": 9,
"nice": 22.7,
"system": 3,
"idle": 64.5,
"iowait": 0,
"irq": 0.4,
"softirq": 0.4,
"steal": 0,
"guest": 0,
"guest_nice": 0,
"timestamp": "2018-02-26T09:16:00.782Z",
"tag": "cpu_percent",
"hostname": "magnesium",
"cpu": "core0"
"fields": {
"timestamp": [
"highlight": {
"tag": [
"@kibana-highlighted-field@cpu_perc@/kibana-highlighted-field@"
"sort": [
1519636560782
Do you have an advice?
maybe the ingested format does not fit the requirements, if so, what format should I use?
