I’m trying to build a template dashboard from data stored in ELS.
Data comes from collectd/logstash, syslog/logstash and metricbeat. All of those use default settings (as described in the software docs). Not specific customization on field types.
I want to be able to select hostnames from a drop-down list so that the dashboard can be more specific, on-demand. I read that I need to use “Templates”. I tried to reproduce what’s describred in http://docs.grafana.org/reference/templating/ but I can’t find the right query to show a hostname list.
In the templating section, I created a new variable and configured:
Label: Hostname
Type: Query
Data source: The ELS source
Refresh: On Time Range Change
Query: {“find”: “terms”, “field”: “host.keyword”}
Regex:
Sort: Alphabetical
This leads to the following error “Templating. Template variables could not be initialized: undefined”.
I tried a bunch of queries but I can’t list my hostnames.
Query: {“find”: “terms”, “field”: “host”} gives the same undefined error.
Query: {“find”: “fields”, “type”: “keyword”} gives the following Preview Of Values: All @version.keyword host.keyword message.keyword procid.keyword programname.keyword type.keyword
What am I doing wrong?
Thank you.
In case it matters, here’s the software I use:
- collectd 5.5.1
- metricbeat 5.6.3
- logstash 5.6.3
- elasticsearch 5.6.3
- grafana 4.5.2
