8.0.2 on ubuntu-server
Datasource is elasticsearch (filled by Graylog) -
I try to use a template variable to display multiple series in a chart.
The basic data structure is: Elasticsearch gets filled every 15 secons through graylog. In the message there are multiple fields regarding the state of the monitored Hyper- server. Included are also the cpu load (type:long) of every virtual machine running on the Hyper-V server. So each message looks like this:
< elasticsearch entry>
application_name: PS-PerfMon
host: hyper-v-server
CPU_Load_Guest_VMName1 Value: long
CPU_Load_Guest_VMName2 Value: long
I created a variable like seen in the picture:
And “tried” to create a graph - but I’m not exactly sure how to reference the variable right.
I basically want to avoid filling out everything by hand - if a VM gets deletet or added, I don’t want to change the graphs. This picture shows what I want to do (in the left one I reference every field by hand - and in the right one I want to use the variable but don’t know how):
- Did you follow any online instructions? If so, what is the URL?
Tried to use this: Elasticsearch | Grafana documentation
