I’ve been using the TIG (Telegraf Influxdb Grafana) stack for a few days now to try to find an alternative to Smokeping.
Thanks to some information found on the internet (Tuto1 or Tuto2) to build the graphics in Granafa, I was able to create some pretty cool graphics.
On the other hand, I realized that the average packet loss in the legend is incorrect (see capture below).
Graph panel settings :
My goal is to find an alternative solution to Smokeping which has proven itself but its frontend is outdated. As long as the indicators in Grafana are not correct I will not be able to switch solution.
TODO :
How to display the right values in the legend ?Post #2- Possibility to have the same graphs as Smokeping (latency + packet loss) ?
Thank you for your help and support.
