Currently your plugin alerts on when a host is not reachable.
Would like to alert when host has 10% packet loss. What are my options? Tried using a singlestat panel but no alerting on this.
Thanks.
Thanks.
Did you figure this out? Are you using the sample alerting dashboard: https://grafana.com/dashboards/1962
As you noticed, alerting is only possible from the graph panel.
averageSeries(worldping.$endpoint.$probe.ping.loss) and substitute the variables for server names. An example:
