In our plugin.json we currently set dependencies.grafanaVersion to 4.x.x. Is that a minimum version, or is there something I need to do to indicate that our plugin also works with 5.x?
The idea is that it should say the minimum version. However in Grafana nor on Grafana.com there’s no restrictions if you would try to use a plugin on Grafana 3.0 that has a minimum version of 4.x.x. Hopefully we can make this a better experience in the future.
Marcus
