Grafana version: 8.1.5
Trying to create a time series dashboard using multi value variable to plot multiple key names on same dashboard.
The only option i can see so far is to use the repeat options → select the variable
However this creates multiple dashboards where i just want all in one dashboard.
My source data is AWS Opensearch. My index has 3 fields
- name
- time
- value
My variable ref the multiple names.
