I have 2 values for memory coming back from a server , actual consumption and buff/cache.
With the buff/cache I would like that to show from the top rather than bottom . As shown in one the screen shots from another application. Is this possible ? I have been playing around with the overrides but cant seem to do it .
Not the solution you are looking for but might be a workaround.
If you multiply the select of your query by -1, it will basically become negative, and you’ll see it from top to bottom. Let me know if that’s okay for your case.
Well, as I said, this is not the solution you are looking for, but this is the idea I provide you haha.
This workaround allow you to visualize your data on a negative part, which is similar to your initial request, but not the same!
