Planning to contribute into xk6-amqp extension
Hi Team,
We are planning to contribute into xk6-amqp extension, but it is archived. Any plan to unarchive it, so we can contribute on same. Otherwise, shall i fork it and contribute. Please suggest.
Thank you..
Hi @mstoykov,
I can see your name as one of the contributor for xk6-amqp extension. We have written code for supporting amqp1.0 version and ready to push the code. shall i fork the repo and contribute, please suggest.
Hi @prmmuthu,
Currently there is no intention for the extension to be maintained by grafana. The original code was PoC and the moment there no plans for it. So if you want this functionality you should fork it and maintain it yourself or just write it from scratch given that it is now using deprecated APIs.
Given that the current code doesn’t make use of the event loop and amqp seems to be pretty asynchronous API from what I know I expect that starting a new is going to be preferable. And maybe amqp1.0 is much different from the pre 1.0, which might also mean the previous code isn’t all that useful as a base.
In all cases, at least at the moment, grafana has no plans to maintain xk6-amqp.
Hope this helps you and best of luck with the extension!
