Hi, i’m using Grafana 10.2.3
I’ve already built the required PIVOT table with Grouping To Matrix Transformation.
This transformation use one row. So i had to concat 3 fields togheter and then i have a lot of YYYY-MM columns with values.
Should be all ok, but the customer does not want repeated rows
so that FROM this template example
AAAA 1111 item1 5 …
AAAA 1111 item2 6…
AAAA 2222 item1 10…
AAAA 2222 item3 9…
BBBB 1111 item2 12
BBBB 1111 item4 15
BBBB 3333 item6 18
i HAVE TO SHOW THIS target template
AAAA 1111 item1 5 …
item2 6…
AAAA 2222 item1 10…
item3 9…
BBBB 1111 item2 12
item4 15
3333 item6 18
Do you have an idea on which kind of transformations i have to use to arrive to this result?
Looking forward to hear from you
THANK YOU!! the Grafana Team
Luigi
PS
I try to load an excel template from/to example
