8.4.9
transform data from row to filed, first column userName do not transform
raw data before transform
What happened?
Not 100% meet my request
This is my expected result:
This is what I can have now:
What other ‘Transforms’ are you using?
I noticed you used 7 in total.
Thanks for your attention to the issue. I extracted data from a {} to get the info I want and do some basic filter to keep useful data.
Any idea to get it done? Thanks for your help
My hunch is that it has something to do with the ‘Group by’ you are using.
Everything is collapsed in your screenshot but it looking at the result it looks like you are grouping by ‘username’
(and double check what is under ‘Organize field’ you can hide columns there too
Try to see what happens if you ‘hide’ (the icon on the right of the transform) the ‘Group by’ transform. Leave the rest visible
And what happens if you change/switch the order (this can effect the end result) of transform are using Drag ‘Group by’ under ‘Rows to fields’
You can do so by clicking and dragging the 6 dots on the end like example below.
Thanks for the reply, I think the problem is I used 2 groupby(userName and previous state), which I have to…
My purpose is to present the data by individual and by how many time they stay on each state. If I only use groupby userName, I will only get sum of total duration of all state. However, I want to break it down.
Now I disable unnecessary step, keep 3 alive. See below picture
before enable rows to filed
after enable rows to filed
transform move userName column into filed, which I wanna keep and drop_duplicate.
I tried to reproduce but I now have a better understanding of your challenge.
To be honest I don’t know if this can be achieved with the ‘Transform’ function(s)
