How to group by row and then use column as row
Hello everybody,
    Grafana v10.1.0 (ff85ec33c5) on Linux
    I’m trying to get better informations. I would like to have only one instance and get “parameter content” and value on columns.
    I’m using Transform badly, i’ll say.
  • What happened?
    Nothing or bad results.
    I have this in entry :
I would like to get this for my users :
    I’ve tried many transform, but i’m not sure what transform i should use.
Please help !
Best regards, Rémi
What is your datasource?
I’m using prometheus.
The transformation is “Group to matrix”
use “parameter” as column, “object” as row and “value” as cell value.
It’s so easy for you ! And for me now.
Thank you so much.
