Performance Issue After Grafana Upgrade to v12.3.3
We are using the open-source version of Grafana, and recently we upgraded Grafana from version 10.3.1 to 12.3.3.
We are using a few additional plugins, including HTML Graphics and the Plotly panel. However, in Grafana v12.3.3, the Plotly panel is no longer supported, so we installed the NLine Plotly plugin instead.
Currently, the graphs appear to work correctly with both HTML Graphics and NLine Plotly. However, we are facing performance issues. The dashboard keeps loading for a long time whenever we select a timestamp or change the time range, while other dashboards are working smoothly without any issues.
Could you please help us investigate and resolve this issue at your earliest convenience?
Thank you.
Does the documentation for both of these plugins say they are supported on 12.3?
Yes, Documentation says it is supported.
