Percentage calculation on 2 queries in Grafana Tempo Data source is not working
  • What Grafana version and what operating system are you using? - Grafana version 12.4.0 (build 19378664917). Cloud Free edition running in a production environment
  • What are you trying to achieve? - Show percentage of successful requests over total requests in a stat panel
  • How are you trying to achieve it? - Used 2 queries where Query A will count_over_time() all the 2xx based on specific endpoints and servicename and Query B to have all the http codes. Then in transformations, I used Add field from calculation but the names Query A and Query B are not showing
  • What happened? - Query A and B is not showing in Add field from calculation>Operation row
  • What did you expect to happen? - the stat panel should display the result of Query A/B *100
  • Can you copy/paste the configuration(s) that you are having problems with? - yes see below
  • Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. - No errors
  • Did you follow any online instructions? If so, what is the URL? I’ve used the grafana AI
