PDF Export Not Available in Grafana OSS v11.5.1
    Docker OSS v11.5.1
    Export a dashboard to PDF
    Using the drop-down menu
  • What happened?
    “Export as PDF” option missing
    “Export as PDF” option to be present
    Not a dashboard configuration issue (I believe)
    No errors that seemed significant:
2025-02-04 12:08:19 logger=settings t=2025-02-04T17:08:19.670560691Z level=info msg="Starting Grafana" version=11.5.1 commit=c6c701cf5be984b088b9d51690b474ab63ca86ff branch=HEAD compiled=2025-02-04T17:08:19Z
2025-02-04 12:08:19 logger=settings t=2025-02-04T17:08:19.670959635Z level=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
2025-02-04 12:08:19 logger=settings t=2025-02-04T17:08:19.670974364Z level=info msg="Config loaded from" file=/etc/grafana/grafana.ini
2025-02-04 12:08:19 logger=settings t=2025-02-04T17:08:19.670978501Z level=info msg="Config overridden from command line" arg="default.paths.data=/var/lib/grafana"
2025-02-04 12:08:19 logger=settings t=2025-02-04T17:08:19.670982147Z level=info msg="Config overridden from command line" arg="default.paths.logs=/var/log/grafana"
2025-02-04 12:08:19 logger=settings t=2025-02-04T17:08:19.670985549Z level=info msg="Config overridden from command line" arg="default.paths.plugins=/var/lib/grafana/plugins"
2025-02-04 12:08:19 logger=settings t=2025-02-04T17:08:19.670988963Z level=info msg="Config overridden from command line" arg="default.paths.provisioning=/etc/grafana/provisioning"
2025-02-04 12:08:19 logger=settings t=2025-02-04T17:08:19.670992444Z level=info msg="Config overridden from command line" arg="default.log.mode=console"
2025-02-04 12:08:19 logger=settings t=2025-02-04T17:08:19.670996171Z level=info msg="Config overridden from Environment variable" var="GF_PATHS_DATA=/var/lib/grafana"
2025-02-04 12:08:19 logger=settings t=2025-02-04T17:08:19.671002108Z level=info msg="Config overridden from Environment variable" var="GF_PATHS_LOGS=/var/log/grafana"
2025-02-04 12:08:19 logger=settings t=2025-02-04T17:08:19.671009218Z level=info msg="Config overridden from Environment variable" var="GF_PATHS_PLUGINS=/var/lib/grafana/plugins"
2025-02-04 12:08:19 logger=settings t=2025-02-04T17:08:19.671012452Z level=info msg="Config overridden from Environment variable" var="GF_PATHS_PROVISIONING=/etc/grafana/provisioning"
2025-02-04 12:08:19 logger=settings t=2025-02-04T17:08:19.671015985Z level=info msg="Config overridden from Environment variable" var="GF_SERVER_ROOT_URL=http://grafana:10001/"
2025-02-04 12:08:19 logger=settings t=2025-02-04T17:08:19.671019179Z level=info msg="Config overridden from Environment variable" var="GF_SERVER_READ_TIMEOUT=30s"
2025-02-04 12:08:19 logger=settings t=2025-02-04T17:08:19.671022725Z level=info msg="Config overridden from Environment variable" var="GF_AUTH_ANONYMOUS_ENABLED=true"
2025-02-04 12:08:19 logger=settings t=2025-02-04T17:08:19.671026027Z level=info msg="Config overridden from Environment variable" var="GF_AUTH_ANONYMOUS_ORG_NAME=Sustaining & Test"
2025-02-04 12:08:19 logger=settings t=2025-02-04T17:08:19.671031716Z level=info msg="Config overridden from Environment variable" var="GF_AUTH_ANONYMOUS_ORG_ROLE=Viewer"
2025-02-04 12:08:19 logger=settings t=2025-02-04T17:08:19.671036936Z level=info msg=Target target=[all]
2025-02-04 12:08:19 logger=settings t=2025-02-04T17:08:19.67104678Z level=info msg="Path Home" path=/usr/share/grafana
2025-02-04 12:08:19 logger=settings t=2025-02-04T17:08:19.671050213Z level=info msg="Path Data" path=/var/lib/grafana
2025-02-04 12:08:19 logger=settings t=2025-02-04T17:08:19.671053381Z level=info msg="Path Logs" path=/var/log/grafana
2025-02-04 12:08:19 logger=settings t=2025-02-04T17:08:19.671056589Z level=info msg="Path Plugins" path=/var/lib/grafana/plugins
2025-02-04 12:08:19 logger=settings t=2025-02-04T17:08:19.671059833Z level=info msg="Path Provisioning" path=/etc/grafana/provisioning
2025-02-04 12:08:19 logger=settings t=2025-02-04T17:08:19.671065272Z level=info msg="App mode production"
2025-02-04 12:08:19 logger=featuremgmt t=2025-02-04T17:08:19.67187533Z level=info msg=FeatureToggles lokiStructuredMetadata=true addFieldFromCalculationStatFunctions=true cloudWatchNewLabelParsing=true openSearchBackendFlowEnabled=true promQLScope=true panelMonitoring=true alertingNoDataErrorExecution=true ssoSettingsApi=true reportingUseRawTimeRange=true influxdbBackendMigration=true dashboardSceneForViewers=true nestedFolders=true lokiLabelNamesQueryApi=true logsInfiniteScrolling=true logsContextDatasourceUi=true alertingSimplifiedRouting=true logsExploreTableVisualisation=true groupToNestedTableTransformation=true dashgpt=true publicDashboardsScene=true prometheusAzureOverrideAudience=true transformationsVariableSupport=true alertingUIOptimizeReducer=true tlsMemcached=true pinNavItems=true transformationsRedesign=true recordedQueriesMulti=true azureMonitorEnableUserAuth=true unifiedRequestLog=true formatString=true alertingInsights=true useSessionStorageForRedirection=true accessActionSets=true correlations=true dashboardScene=true logRowsPopoverMenu=true angularDeprecationUI=true cloudWatchRoundUpEndTime=true awsAsyncQueryCaching=true zipkinBackendMigration=true alertingApiServer=true onPremToCloudMigrations=true dataplaneFrontendFallback=true lokiQueryHints=true preinstallAutoUpdate=true accessControlOnCall=true dashboardSceneSolo=true kubernetesPlaylists=true lokiQuerySplitting=true managedPluginsInstall=true cloudWatchCrossAccountQuerying=true userStorageAPI=true exploreMetrics=true newPDFRendering=true annotationPermissionUpdate=true newDashboardSharingComponent=true recoveryThreshold=true newFiltersUI=true
2025-02-04 12:08:19 logger=sqlstore t=2025-02-04T17:08:19.676035142Z level=info msg="Connecting to DB" dbtype=sqlite3
2025-02-04 12:08:19 logger=migrator t=2025-02-04T17:08:19.70467741Z level=info msg="Locking database"
2025-02-04 12:08:19 logger=migrator t=2025-02-04T17:08:19.704715268Z level=info msg="Starting DB migrations"
2025-02-04 12:08:19 logger=migrator t=2025-02-04T17:08:19.731143377Z level=info msg="Executing migration" id="update service accounts login field orgid to appear only once"
2025-02-04 12:08:19 logger=migrator t=2025-02-04T17:08:19.733199647Z level=info msg="Migration successfully executed" id="update service accounts login field orgid to appear only once" duration=2.049852ms
2025-02-04 12:08:19 logger=migrator t=2025-02-04T17:08:19.747952923Z level=info msg="Executing migration" id="Add column dashboard_uid in star"
2025-02-04 12:08:19 logger=migrator t=2025-02-04T17:08:19.762850066Z level=info msg="Migration successfully executed" id="Add column dashboard_uid in star" duration=14.890064ms
2025-02-04 12:08:19 logger=migrator t=2025-02-04T17:08:19.775338157Z level=info msg="Executing migration" id="Add column org_id in star"
2025-02-04 12:08:19 logger=migrator t=2025-02-04T17:08:19.798544438Z level=info msg="Migration successfully executed" id="Add column org_id in star" duration=23.202935ms
2025-02-04 12:08:19 logger=migrator t=2025-02-04T17:08:19.818169894Z level=info msg="Executing migration" id="Add column updated in star"
2025-02-04 12:08:19 logger=migrator t=2025-02-04T17:08:19.835664921Z level=info msg="Migration successfully executed" id="Add column updated in star" duration=17.484065ms
2025-02-04 12:08:19 logger=migrator t=2025-02-04T17:08:19.848498731Z level=info msg="Executing migration" id="add index in star table on dashboard_uid, org_id and user_id columns"
2025-02-04 12:08:19 logger=migrator t=2025-02-04T17:08:19.856316529Z level=info msg="Migration successfully executed" id="add index in star table on dashboard_uid, org_id and user_id columns" duration=7.816598ms
2025-02-04 12:08:19 logger=migrator t=2025-02-04T17:08:19.869326539Z level=info msg="Executing migration" id="Add column dashboard_uid in dashboard_tag"
2025-02-04 12:08:19 logger=migrator t=2025-02-04T17:08:19.879310871Z level=info msg="Migration successfully executed" id="Add column dashboard_uid in dashboard_tag" duration=9.977703ms
2025-02-04 12:08:19 logger=migrator t=2025-02-04T17:08:19.892541486Z level=info msg="Executing migration" id="Add column org_id in dashboard_tag"
2025-02-04 12:08:19 logger=migrator t=2025-02-04T17:08:19.909401879Z level=info msg="Migration successfully executed" id="Add column org_id in dashboard_tag" duration=16.856304ms
2025-02-04 12:08:19 logger=migrator t=2025-02-04T17:08:19.918426139Z level=info msg="Executing migration" id="Add missing dashboard_uid and org_id to dashboard_tag"
2025-02-04 12:08:19 logger=migrator t=2025-02-04T17:08:19.920183894Z level=info msg="Migration successfully executed" id="Add missing dashboard_uid and org_id to dashboard_tag" duration=1.758773ms
2025-02-04 12:08:19 logger=migrator t=2025-02-04T17:08:19.930523321Z level=info msg="Executing migration" id="Add missing dashboard_uid and org_id to star"
2025-02-04 12:08:19 logger=migrator t=2025-02-04T17:08:19.932317996Z level=info msg="Migration successfully executed" id="Add missing dashboard_uid and org_id to star" duration=1.79253ms
2025-02-04 12:08:19 logger=migrator t=2025-02-04T17:08:19.945139444Z level=info msg="Executing migration" id="update NULL org_id to 1"
2025-02-04 12:08:19 logger=migrator t=2025-02-04T17:08:19.947401637Z level=info msg="Migration successfully executed" id="update NULL org_id to 1" duration=2.256557ms
2025-02-04 12:08:19 logger=migrator t=2025-02-04T17:08:19.963910278Z level=info msg="Executing migration" id="make org_id NOT NULL and DEFAULT VALUE 1"
2025-02-04 12:08:19 logger=migrator t=2025-02-04T17:08:19.98813677Z level=info msg="Migration successfully executed" id="make org_id NOT NULL and DEFAULT VALUE 1" duration=24.226345ms
2025-02-04 12:08:19 logger=migrator t=2025-02-04T17:08:19.998975917Z level=info msg="Executing migration" id="Increase prev_state column to length 40 not null"
2025-02-04 12:08:19 logger=migrator t=2025-02-04T17:08:19.999077549Z level=info msg="Migration successfully executed" id="Increase prev_state column to length 40 not null" duration=101.808µs
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.01055347Z level=info msg="Executing migration" id="Increase new_state column to length 40 not null"
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.010624147Z level=info msg="Migration successfully executed" id="Increase new_state column to length 40 not null" duration=74.847µs
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.021947573Z level=info msg="Executing migration" id="add unique index team_member_user_id_org_id"
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.026961701Z level=info msg="Migration successfully executed" id="add unique index team_member_user_id_org_id" duration=5.006476ms
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.037034975Z level=info msg="Executing migration" id="add external_session_id to user_auth_token"
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.044785318Z level=info msg="Migration successfully executed" id="add external_session_id to user_auth_token" duration=7.745825ms
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.053653574Z level=info msg="Executing migration" id="add group mapping UID column to user_role table"
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.06542288Z level=info msg="Migration successfully executed" id="add group mapping UID column to user_role table" duration=11.762543ms
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.074918138Z level=info msg="Executing migration" id="add user_role org ID, user ID, role ID, group mapping UID index"
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.08050208Z level=info msg="Migration successfully executed" id="add user_role org ID, user ID, role ID, group mapping UID index" duration=5.581108ms
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.09121884Z level=info msg="Executing migration" id="remove user_role org ID, user ID, role ID index"
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.099008602Z level=info msg="Migration successfully executed" id="remove user_role org ID, user ID, role ID index" duration=7.785897ms
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.109543159Z level=info msg="Executing migration" id="add type column"
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.131520082Z level=info msg="Migration successfully executed" id="add type column" duration=21.973036ms
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.14080482Z level=info msg="Executing migration" id="Remove unique index UQE_folder_org_id_parent_uid_title"
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.144951687Z level=info msg="Migration successfully executed" id="Remove unique index UQE_folder_org_id_parent_uid_title" duration=4.135373ms
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.153965571Z level=info msg="Executing migration" id="Remove unique index for dashboard_org_id_folder_uid_title_is_folder"
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.158861119Z level=info msg="Migration successfully executed" id="Remove unique index for dashboard_org_id_folder_uid_title_is_folder" duration=4.895577ms
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.168938637Z level=info msg="Executing migration" id="add cloud_migration_resource.name column"
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.182330153Z level=info msg="Migration successfully executed" id="add cloud_migration_resource.name column" duration=13.386589ms
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.193986608Z level=info msg="Executing migration" id="add cloud_migration_resource.parent_name column"
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.205913411Z level=info msg="Migration successfully executed" id="add cloud_migration_resource.parent_name column" duration=11.92482ms
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.220558929Z level=info msg="Executing migration" id="add cloud_migration_session.org_id column"
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.229484283Z level=info msg="Migration successfully executed" id="add cloud_migration_session.org_id column" duration=8.923119ms
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.239525324Z level=info msg="Executing migration" id="add cloud_migration_resource.error_code column"
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.249253636Z level=info msg="Migration successfully executed" id="add cloud_migration_resource.error_code column" duration=9.726708ms
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.265091828Z level=info msg="Executing migration" id="increase resource_uid column length"
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.265181728Z level=info msg="Migration successfully executed" id="increase resource_uid column length" duration=92.175µs
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.280087337Z level=info msg="Executing migration" id="Add scope to alert.notifications.receivers:read and alert.notifications.receivers.secrets:read"
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.284972852Z level=info msg="Migration successfully executed" id="Add scope to alert.notifications.receivers:read and alert.notifications.receivers.secrets:read" duration=4.882073ms
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.295304395Z level=info msg="Executing migration" id="add metadata column to alert_rule table"
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.304011133Z level=info msg="Migration successfully executed" id="add metadata column to alert_rule table" duration=8.703684ms
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.327502135Z level=info msg="Executing migration" id="add metadata column to alert_rule_version table"
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.345223265Z level=info msg="Migration successfully executed" id="add metadata column to alert_rule_version table" duration=17.717364ms
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.35525298Z level=info msg="Executing migration" id="delete orphaned service account permissions"
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.360727198Z level=info msg="Migration successfully executed" id="delete orphaned service account permissions" duration=5.468856ms
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.373526072Z level=info msg="Executing migration" id="adding action set permissions"
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.382150792Z level=info msg="Migration successfully executed" id="adding action set permissions" duration=8.627144ms
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.391769424Z level=info msg="Executing migration" id="create user_external_session table"
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.395634021Z level=info msg="Migration successfully executed" id="create user_external_session table" duration=3.86212ms
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.404839246Z level=info msg="Executing migration" id="increase name_id column length to 1024"
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.404934824Z level=info msg="Migration successfully executed" id="increase name_id column length to 1024" duration=103.619µs
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.417122656Z level=info msg="Executing migration" id="increase session_id column length to 1024"
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.417205452Z level=info msg="Migration successfully executed" id="increase session_id column length to 1024" duration=85.571µs
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.431987563Z level=info msg="Executing migration" id="remove scope from alert.notifications.receivers:create"
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.444514617Z level=info msg="Migration successfully executed" id="remove scope from alert.notifications.receivers:create" duration=12.513523ms
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.469984083Z level=info msg="migrations completed" performed=35 skipped=594 duration=738.948621ms
2025-02-04 12:08:20 logger=migrator t=2025-02-04T17:08:20.472425922Z level=info msg="Unlocking database"
2025-02-04 12:08:20 logger=secrets t=2025-02-04T17:08:20.515420043Z level=info msg="Envelope encryption state" enabled=true currentprovider=secretKey.v1
2025-02-04 12:08:20 logger=plugin.angulardetectorsprovider.dynamic t=2025-02-04T17:08:20.702465262Z level=info msg="Restored cache from database" duration=1.251466ms
2025-02-04 12:08:20 logger=plugin.store t=2025-02-04T17:08:20.720116047Z level=info msg="Loading plugins..."
2025-02-04 12:08:20 logger=local.finder t=2025-02-04T17:08:20.762979839Z level=warn msg="Skipping finding plugins as directory does not exist" path=/usr/share/grafana/plugins-bundled
2025-02-04 12:08:21 logger=plugins.registration t=2025-02-04T17:08:21.86822292Z level=info msg="Plugin registered" pluginId=grafana-github-datasource
2025-02-04 12:08:21 logger=plugin.store t=2025-02-04T17:08:21.868251098Z level=info msg="Plugins loaded" count=55 duration=1.148136825s
2025-02-04 12:08:21 logger=resource-migrator t=2025-02-04T17:08:21.87412327Z level=info msg="Locking database"
2025-02-04 12:08:21 logger=resource-migrator t=2025-02-04T17:08:21.874150694Z level=info msg="Starting DB migrations"
2025-02-04 12:08:21 logger=resource-migrator t=2025-02-04T17:08:21.878878119Z level=info msg="Executing migration" id="create resource_migration_log table"
2025-02-04 12:08:21 logger=resource-migrator t=2025-02-04T17:08:21.884463472Z level=info msg="Migration successfully executed" id="create resource_migration_log table" duration=5.582136ms
2025-02-04 12:08:21 logger=resource-migrator t=2025-02-04T17:08:21.894557725Z level=info msg="Executing migration" id="Initialize resource tables"
2025-02-04 12:08:21 logger=resource-migrator t=2025-02-04T17:08:21.894729186Z level=info msg="Migration successfully executed" id="Initialize resource tables" duration=173.333µs
2025-02-04 12:08:21 logger=resource-migrator t=2025-02-04T17:08:21.907308348Z level=info msg="Executing migration" id="drop table resource"
2025-02-04 12:08:21 logger=resource-migrator t=2025-02-04T17:08:21.908812997Z level=info msg="Migration successfully executed" id="drop table resource" duration=1.501849ms
2025-02-04 12:08:21 logger=resource-migrator t=2025-02-04T17:08:21.91948606Z level=info msg="Executing migration" id="create table resource"
2025-02-04 12:08:21 logger=resource-migrator t=2025-02-04T17:08:21.923814644Z level=info msg="Migration successfully executed" id="create table resource" duration=4.325595ms
2025-02-04 12:08:21 logger=resource-migrator t=2025-02-04T17:08:21.934147356Z level=info msg="Executing migration" id="create table resource, index: 0"
2025-02-04 12:08:21 logger=resource-migrator t=2025-02-04T17:08:21.939925136Z level=info msg="Migration successfully executed" id="create table resource, index: 0" duration=5.772924ms
2025-02-04 12:08:21 logger=resource-migrator t=2025-02-04T17:08:21.949297333Z level=info msg="Executing migration" id="drop table resource_history"
2025-02-04 12:08:21 logger=resource-migrator t=2025-02-04T17:08:21.950401903Z level=info msg="Migration successfully executed" id="drop table resource_history" duration=1.09966ms
2025-02-04 12:08:21 logger=resource-migrator t=2025-02-04T17:08:21.961659881Z level=info msg="Executing migration" id="create table resource_history"
2025-02-04 12:08:21 logger=resource-migrator t=2025-02-04T17:08:21.967106472Z level=info msg="Migration successfully executed" id="create table resource_history" duration=5.424441ms
2025-02-04 12:08:21 logger=resource-migrator t=2025-02-04T17:08:21.9858656Z level=info msg="Executing migration" id="create table resource_history, index: 0"
2025-02-04 12:08:21 logger=resource-migrator t=2025-02-04T17:08:21.994296509Z level=info msg="Migration successfully executed" id="create table resource_history, index: 0" duration=8.428025ms
2025-02-04 12:08:22 logger=resource-migrator t=2025-02-04T17:08:22.007675123Z level=info msg="Executing migration" id="create table resource_history, index: 1"
2025-02-04 12:08:22 logger=resource-migrator t=2025-02-04T17:08:22.012682701Z level=info msg="Migration successfully executed" id="create table resource_history, index: 1" duration=5.009165ms
2025-02-04 12:08:22 logger=resource-migrator t=2025-02-04T17:08:22.022255376Z level=info msg="Executing migration" id="drop table resource_version"
2025-02-04 12:08:22 logger=resource-migrator t=2025-02-04T17:08:22.023748447Z level=info msg="Migration successfully executed" id="drop table resource_version" duration=1.486881ms
2025-02-04 12:08:22 logger=resource-migrator t=2025-02-04T17:08:22.035346156Z level=info msg="Executing migration" id="create table resource_version"
2025-02-04 12:08:22 logger=resource-migrator t=2025-02-04T17:08:22.040138889Z level=info msg="Migration successfully executed" id="create table resource_version" duration=4.78942ms
2025-02-04 12:08:22 logger=resource-migrator t=2025-02-04T17:08:22.049166666Z level=info msg="Executing migration" id="create table resource_version, index: 0"
2025-02-04 12:08:22 logger=resource-migrator t=2025-02-04T17:08:22.053985154Z level=info msg="Migration successfully executed" id="create table resource_version, index: 0" duration=4.810633ms
2025-02-04 12:08:22 logger=resource-migrator t=2025-02-04T17:08:22.064376004Z level=info msg="Executing migration" id="drop table resource_blob"
2025-02-04 12:08:22 logger=resource-migrator t=2025-02-04T17:08:22.065760778Z level=info msg="Migration successfully executed" id="drop table resource_blob" duration=1.381999ms
2025-02-04 12:08:22 logger=resource-migrator t=2025-02-04T17:08:22.076490793Z level=info msg="Executing migration" id="create table resource_blob"
2025-02-04 12:08:22 logger=resource-migrator t=2025-02-04T17:08:22.080740759Z level=info msg="Migration successfully executed" id="create table resource_blob" duration=4.247059ms
2025-02-04 12:08:22 logger=resource-migrator t=2025-02-04T17:08:22.0918819Z level=info msg="Executing migration" id="create table resource_blob, index: 0"
2025-02-04 12:08:22 logger=resource-migrator t=2025-02-04T17:08:22.097528944Z level=info msg="Migration successfully executed" id="create table resource_blob, index: 0" duration=5.645234ms
2025-02-04 12:08:22 logger=resource-migrator t=2025-02-04T17:08:22.107219053Z level=info msg="Executing migration" id="create table resource_blob, index: 1"
2025-02-04 12:08:22 logger=resource-migrator t=2025-02-04T17:08:22.112359184Z level=info msg="Migration successfully executed" id="create table resource_blob, index: 1" duration=5.138467ms
2025-02-04 12:08:22 logger=resource-migrator t=2025-02-04T17:08:22.122913015Z level=info msg="Executing migration" id="Add column previous_resource_version in resource_history"
2025-02-04 12:08:22 logger=resource-migrator t=2025-02-04T17:08:22.139332715Z level=info msg="Migration successfully executed" id="Add column previous_resource_version in resource_history" duration=16.414215ms
2025-02-04 12:08:22 logger=resource-migrator t=2025-02-04T17:08:22.149379923Z level=info msg="Executing migration" id="Add column previous_resource_version in resource"
2025-02-04 12:08:22 logger=resource-migrator t=2025-02-04T17:08:22.160264746Z level=info msg="Migration successfully executed" id="Add column previous_resource_version in resource" duration=10.870953ms
2025-02-04 12:08:22 logger=resource-migrator t=2025-02-04T17:08:22.169772418Z level=info msg="Executing migration" id="Add index to resource_history for polling"
2025-02-04 12:08:22 logger=resource-migrator t=2025-02-04T17:08:22.177204347Z level=info msg="Migration successfully executed" id="Add index to resource_history for polling" duration=7.430319ms
2025-02-04 12:08:22 logger=resource-migrator t=2025-02-04T17:08:22.189218915Z level=info msg="Executing migration" id="Add index to resource for loading"
2025-02-04 12:08:22 logger=resource-migrator t=2025-02-04T17:08:22.19387867Z level=info msg="Migration successfully executed" id="Add index to resource for loading" duration=4.658542ms
2025-02-04 12:08:22 logger=resource-migrator t=2025-02-04T17:08:22.203588518Z level=info msg="Executing migration" id="Add column folder in resource_history"
2025-02-04 12:08:22 logger=resource-migrator t=2025-02-04T17:08:22.214827183Z level=info msg="Migration successfully executed" id="Add column folder in resource_history" duration=11.234212ms
2025-02-04 12:08:22 logger=resource-migrator t=2025-02-04T17:08:22.22461686Z level=info msg="Executing migration" id="Add column folder in resource"
2025-02-04 12:08:22 logger=resource-migrator t=2025-02-04T17:08:22.238705548Z level=info msg="Migration successfully executed" id="Add column folder in resource" duration=14.085485ms
2025-02-04 12:08:22 logger=resource-migrator t=2025-02-04T17:08:22.248745389Z level=info msg="migrations completed" performed=22 skipped=0 duration=369.97404ms
2025-02-04 12:08:22 logger=resource-migrator t=2025-02-04T17:08:22.252930936Z level=info msg="Unlocking database"
2025-02-04 12:08:22 logger=query_data t=2025-02-04T17:08:22.270384729Z level=info msg="Query Service initialization"
2025-02-04 12:08:22 logger=live.push_http t=2025-02-04T17:08:22.280009638Z level=info msg="Live Push Gateway initialization"
2025-02-04 12:08:22 logger=ngalert.notifier.alertmanager org=1 t=2025-02-04T17:08:22.286954398Z level=info msg="Applying new configuration to Alertmanager" configHash=d2c56faca6af2a5772ff4253222f7386
2025-02-04 12:08:22 logger=ngalert.state.manager t=2025-02-04T17:08:22.304094613Z level=info msg="Running in alternative execution of Error/NoData mode"
2025-02-04 12:08:22 logger=cloudmigration.service t=2025-02-04T17:08:22.307648582Z level=info msg="using gcom client for auth"
2025-02-04 12:08:22 logger=infra.usagestats.collector t=2025-02-04T17:08:22.307750209Z level=info msg="registering usage stat providers" usageStatsProvidersLen=2
2025-02-04 12:08:22 logger=provisioning.alerting t=2025-02-04T17:08:22.310866251Z level=info msg="starting to provision alerting"
2025-02-04 12:08:22 logger=provisioning.alerting t=2025-02-04T17:08:22.310887772Z level=info msg="finished to provision alerting"
2025-02-04 12:08:22 logger=plugin.backgroundinstaller t=2025-02-04T17:08:22.311305212Z level=info msg="Installing plugin" pluginId=grafana-lokiexplore-app version=
2025-02-04 12:08:22 logger=http.server t=2025-02-04T17:08:22.314625933Z level=info msg="HTTP Server Listen" address=[::]:3000 protocol=http subUrl= socket=
2025-02-04 12:08:22 logger=ngalert.state.manager t=2025-02-04T17:08:22.314968126Z level=info msg="Warming state cache for startup"
2025-02-04 12:08:22 logger=grafanaStorageLogger t=2025-02-04T17:08:22.319509957Z level=info msg="Storage starting"
2025-02-04 12:08:22 logger=ngalert.multiorg.alertmanager t=2025-02-04T17:08:22.320151698Z level=info msg="Starting MultiOrg Alertmanager"
2025-02-04 12:08:22 logger=grafana.update.checker t=2025-02-04T17:08:22.320189367Z level=error msg="Update check failed" error="failed to get stable version from grafana.com: Get \"https://grafana.com/api/grafana/versions/stable\": dial tcp: lookup grafana.com on 127.0.0.11:53: no such host" duration=359.633µs
2025-02-04 12:08:22 logger=plugin.backgroundinstaller t=2025-02-04T17:08:22.320228339Z level=error msg="Failed to install plugin" pluginId=grafana-lokiexplore-app version= error="Get \"https://grafana.com/api/plugins/grafana-lokiexplore-app/versions\": dial tcp: lookup grafana.com on 127.0.0.11:53: no such host"
2025-02-04 12:08:22 logger=plugin.backgroundinstaller t=2025-02-04T17:08:22.32024804Z level=info msg="Installing plugin" pluginId=grafana-pyroscope-app version=
2025-02-04 12:08:22 logger=plugin.backgroundinstaller t=2025-02-04T17:08:22.325452219Z level=error msg="Failed to install plugin" pluginId=grafana-pyroscope-app version= error="Get \"https://grafana.com/api/plugins/grafana-pyroscope-app/versions\": dial tcp: lookup grafana.com on 127.0.0.11:53: no such host"
2025-02-04 12:08:22 logger=plugin.signature.key_retriever t=2025-02-04T17:08:22.334551595Z level=error msg="Error downloading plugin manifest keys" error="Get \"https://grafana.com/api/plugins/ci/keys\": dial tcp: lookup grafana.com on 127.0.0.11:53: no such host"
2025-02-04 12:08:22 logger=ngalert.state.manager t=2025-02-04T17:08:22.403813304Z level=info msg="State cache has been initialized" states=0 duration=88.84237ms
2025-02-04 12:08:22 logger=ngalert.scheduler t=2025-02-04T17:08:22.403865091Z level=info msg="Starting scheduler" tickInterval=10s maxAttempts=3
2025-02-04 12:08:22 logger=ticker t=2025-02-04T17:08:22.403929737Z level=info msg=starting first_tick=2025-02-04T17:08:30Z
2025-02-04 12:08:22 logger=plugin.angulardetectorsprovider.dynamic t=2025-02-04T17:08:22.414833051Z level=error msg="Error while updating detectors" error="fetch: http do: Get \"https://grafana.com/api/plugins/angular_patterns\": dial tcp: lookup grafana.com on 127.0.0.11:53: no such host"
2025-02-04 12:08:22 logger=plugin.angulardetectorsprovider.dynamic t=2025-02-04T17:08:22.414975198Z level=info msg="Patterns update finished" duration=11.153223ms
2025-02-04 12:08:22 logger=provisioning.dashboard t=2025-02-04T17:08:22.417298015Z level=info msg="starting to provision dashboards"
2025-02-04 12:08:22 logger=provisioning.dashboard t=2025-02-04T17:08:22.417332768Z level=info msg="finished to provision dashboards"
2025-02-04 12:08:22 logger=grafana-apiserver t=2025-02-04T17:08:22.748149894Z level=info msg="Adding GroupVersion playlist.grafana.app v0alpha1 to ResourceManager"
2025-02-04 12:08:22 logger=resource-server t=2025-02-04T17:08:22.748256036Z level=warn msg="failed to register storage metrics" error="duplicate metrics collector registration attempted"
2025-02-04 12:08:22 logger=resource-server t=2025-02-04T17:08:22.748355652Z level=warn msg="failed to register storage metrics" error="duplicate metrics collector registration attempted"
2025-02-04 12:08:22 logger=resource-server t=2025-02-04T17:08:22.748401086Z level=warn msg="failed to register storage metrics" error="duplicate metrics collector registration attempted"
2025-02-04 12:08:22 logger=grafana-apiserver t=2025-02-04T17:08:22.752198527Z level=info msg="Adding GroupVersion dashboard.grafana.app v0alpha1 to ResourceManager"
2025-02-04 12:08:22 logger=grafana-apiserver t=2025-02-04T17:08:22.753816348Z level=info msg="Adding GroupVersion dashboard.grafana.app v1alpha1 to ResourceManager"
2025-02-04 12:08:22 logger=grafana-apiserver t=2025-02-04T17:08:22.755166331Z level=info msg="Adding GroupVersion dashboard.grafana.app v2alpha1 to ResourceManager"
2025-02-04 12:08:22 logger=grafana-apiserver t=2025-02-04T17:08:22.75623545Z level=info msg="Adding GroupVersion featuretoggle.grafana.app v0alpha1 to ResourceManager"
2025-02-04 12:08:22 logger=grafana-apiserver t=2025-02-04T17:08:22.762422158Z level=info msg="Adding GroupVersion iam.grafana.app v0alpha1 to ResourceManager"
2025-02-04 12:08:22 logger=grafana-apiserver t=2025-02-04T17:08:22.770245851Z level=info msg="Adding GroupVersion notifications.alerting.grafana.app v0alpha1 to ResourceManager"
2025-02-04 12:08:22 logger=grafana-apiserver t=2025-02-04T17:08:22.772415683Z level=info msg="Adding GroupVersion userstorage.grafana.app v0alpha1 to ResourceManager"
2025-02-04 12:08:22 logger=app-registry t=2025-02-04T17:08:22.83844149Z level=info msg="app registry initialized"
2025-02-04 12:09:22 logger=plugin.signature.key_retriever t=2025-02-04T17:09:22.350856006Z level=error msg="Error downloading plugin manifest keys" error="Get \"https://grafana.com/api/plugins/ci/keys\": dial tcp: lookup grafana.com on 127.0.0.11:53: no such host"
2025-02-04 12:09:59 logger=infra.usagestats t=2025-02-04T17:09:59.365368195Z level=info msg="Usage stats are ready to report"
    Documentation
    Docs and release notes for v11.5 say this should be available for OSS.
Link to release notes: (What's new in Grafana v11.5 | Grafana documentation)
Nevermind, apparently only the dedicated feature page mentions that it’s only for “Grafana Cloud”, not including OSS:
(Redesigned sharing experience in Dashboards | Grafana Cloud documentation)
Is it really? From what I understood it is Generally Available, so I thought for OSS too.
Yeah, if I was just someone not reading the release notes and just looking at the top of the page of the standard documentation (Share dashboards and panels | Grafana Cloud documentation), I would assume that it should be in OSS too since that’s what’s shown at the top of the page:
There shouldn’t be any assumptions. The release notes clearly state:
This new PDF generation method now replaces the old one and is generally available for everyone.
There is also an issue tracking this; no comment from the Grafana team though.
May be enabling of newPDFRendering feature toggle would help?
I haven’t tested on my own yet to see if that feature toggle would actually enable it, but according to the docs regarding feature toggles, it should be “enabled by default”.
Speaking broadly, I want to make clear, while this is a feature that I myself VERY highly desire, I’m not going to “demand” or try to push that this be made available. I hugely appreciate Grafana Labs making a free and open-source version with all the capabilities it currently has, and consider the company very gracious for doing so.
My objective is to get clarification so that I can either expect to eventually see it in OSS or not.
I did do that. On startup Grafana even logged the feature is enabled.
logger=featuremgmt t=2025-03-05T13:55:04.157442142Z level=info msg=FeatureToggles ... newPDFRendering=true ...
I have not explicitly set that feature toggle, and I also see it set to True for me. So I don’t think an explicit flag being set would make a difference since the default setting is correctly being respected.
This discussion may be closed.
The feature has been revoked from the OSS version.
Hi. This is an enterprise feature. Sorry for the inconvenience. We’ll be updating the docs accordingly so they’re well-understood
