Passing Absolute time range in MQL query
    Grafana v8.5.1 Windows10
    Passing selected Time Range value to MQL query
by MQL do you mean MSSQL?
Hi Mattabrams,
Thank you for replaying back. By MQL
I know this thread is old but I’ve been trying to solve this for a long time and just now find a simple solution:
fetch logging_bucket
|metric ‘logging.googleapis.com/user/my_metric
| every mul(1ms,($__to - $__from))
| group_by [ ], percentile(val(),95)
We can use the grafana variables __to and __from to quickly calculate how many milliseconds are in the time range (__range is not available in mql), then we can multiply the duration 1ms by this amount to create a duration which is the same length of the time range.
I haven’t found anyone else mentioning this online, so hopefully this can help someone.
