I am very new to the grafana and logging ecosystem ive been able to setup log sending but I have no idea how to get the logs visualized. There seems to be no good tutorials/documentation to help do what i would like to do.
I am trying to display the top ten most common source IP that shows up in my firewall logs. I was trying to build off of that but nothing including using 3 gpt apps couldnt help me. Ive tried regex, ive tried different graphs but i cannot get to the end result. I can get the regex to label the source ip but i cannot visualize the top ten most common ips. I want to do more complex stuff but cant even do this.
Pfsense firewall log
2024-12-06T19:52:25.669653-08:00 test.test.test filterlog 77859 - - 4,,,1000000103,em0,match,block,in,4,0x0,,53,0,0,DF,17,udp,61,157.240.22.19,72.203.171.222,443,13504,41
promtail yaml
server:
http_listen_port: 9080
grpc_listen_port: 0
positions:
filename: /tmp/positions.yaml
clients:
- url: http://loki:3100/loki/api/v1/push
scrape_configs:
# Job for system logs (default system logs like syslog, auth.log, kern.log, etc.)
- job_name: system
static_configs:
- targets:
- localhost
labels:
job: system
__path__: /var/log/syslog
# Job for syslog-ng logs forwarded via unique port (e.g., 10514)
- job_name: syslog
syslog:
listen_address: 0.0.0.0:5514 # Listening for syslog messages on port 5514
listen_protocol: tcp # Using TCP for syslog messages
idle_timeout: 60s # Timeout after 60 seconds of inactivity
label_structured_data: yes # Include structured data from syslog header as labels
labels:
job: "syslog" # Constant label for all syslog entries
relabel_configs:
- source_labels: ['__syslog_message_hostname']
target_label: 'host' # Relabel syslog hostname field as "host"
pipeline_stages:
- regex:
expression: '^\\S+\\s+\\S+\\s+\\S+\\s+\\S+\\s+-\\s+-\\s+\\S+,,,.*,(?P<interface>\\S+),.*,(?P<action>block|pass),.*,(?P<ip_version>\\d+),.*,(?P<protocol>\\S+),.*,(?P<source_ip>\\d{1,3}\\.\\d{1,3}\\.\\d{1,3}\\.\\d{1,3}),(?P<destination_ip>\\d{1,3}\\.\\d{1,3}\\.\\d{1,3}\\.\\d{1,3}),.*'
- labels:
interface:
action:
ip_version:
protocol:
source_ip:
destination_ip:
loki yaml
auth_enabled: false
server:
http_listen_port: 3100
grpc_listen_port: 9096
common:
instance_addr: 127.0.0.1
path_prefix: /tmp/loki
storage:
filesystem:
chunks_directory: /tmp/loki/chunks
rules_directory: /tmp/loki/rules
replication_factor: 1
ring:
kvstore:
store: inmemory
query_range:
results_cache:
cache:
embedded_cache:
enabled: true
max_size_mb: 100
schema_config:
configs:
store: tsdb
object_store: filesystem
schema: v13
index:
prefix: index_
period: 24h
limits_config:
ingestion_rate_mb: 10
ingestion_burst_size_mb: 20
max_line_size: 256KB
max_streams_per_user: 10000
max_global_streams_per_user: 20000
reject_old_samples: true
reject_old_samples_max_age: 24h
max_query_series: 10000
ruler:
alertmanager_url: http://localhost:9093
# By default, Loki will send anonymous, but uniquely-identifiable usage and configuration
# analytics to Grafana Labs. These statistics are sent to https://stats.grafana.org/
# Statistics help us better understand how Loki is used, and they show us performance
# levels for most users. This helps us prioritize features and documentation.
# For more information on what's sent, look at
# https://github.com/grafana/loki/blob/main/pkg/analytics/stats.go
# Refer to the buildReport method to see what goes into a report.
# If you would like to disable reporting, uncomment the following lines:
#analytics:
# reporting_enabled: false
