Hi everyone!
Grafana 8.3.3 with Prometheus 2.32.1 on Kubernetes. -
I’m trying to create a panel in Grafana that calculates the percentage difference in the value of two other panels. However, those two panels reference completely different time ranges, which are overridden using query options, so I can’t reuse the PromQL queries directly. -
I can see that Grafana allows the use of another panel as a data source, but it doesn’t seem to expose a way to actually perform any calculations on the referenced data. There also doesn’t seem to be a way to specify multiple time ranges for a single panel.
Is there a way to achieve what I’m trying to implement here?
Apologies if my explanation isn’t great, I’m relatively new to Grafana and am still finding my way around the terminology.
Thanks.
