I’m using Promtail (same version to send logs from two K8s clusters (QA and PROD), both installations use the same helm chart values for Promtail, and both applications log messages in JSON format as follows:
Prod environment:
❯ echo '{"timestamp":"2024-03-27T07:18:05.574Z","level":"WARN","thread":"grpc-executor-3","logger":"REDACTED","message":"REDACTED","context":"default"}' | jq
"timestamp": "2024-03-27T07:18:05.574Z",
"level": "WARN",
"thread": "grpc-executor-3",
"logger": "REDACTED",
"message": "REDACTED",
"context": "default"
QA environment:
❯ echo '{"timestamp":"2024-03-26T19:53:47.425Z","level":"INFO","thread":"http-nio-8024-exec-5","logger":"AUDIT.io.axoniq.axonserver.rest.BackupInfoRestCon
troller","message":"REDACTED","context":"default"}' | jq
"timestamp": "2024-03-26T19:53:47.425Z",
"level": "INFO",
"thread": "http-nio-8024-exec-5",
As you guys can see, both log messages are valid JSON values.
The issue is: the panel log doesn’t show the logs from the Prod environment the same way it shows the logs from the QA environment.
Here is how the logs from QA appears:
Here is how the logs from Prod appear:
Both screenshots are from the same Dashboard, I just changed the cluster variable on the top.
Here are the values I’m using in the helm chart:
snippets:
pipelineStages:
- cri: {}
- static_labels:
cluster: ${cluster_id}
- json:
expressions:
timestamp: timestamp
level: level
thread: thread
class: logger
message: message
context: context
- labels:
level:
class:
context:
thread:
project_code:
- timestamp:
format: RFC3339
source: timestamp
- output:
source: message
What am I doing wrong?
