Panel Datasource not accessable when using collapsed row
    Grafana 9 on Centos 8
    Using a table panel as a datasource for other panels in the same dashboard.
    Link SQL query to Table panel, then link other panels to panel datasource.
  • What happened?
    When the table panel is visible the panels using it as a datasource populate, however, if you put the table panel in a collapsed Row to hide the source data from view, the panels using the table as a datasource are unable to access the data. i assume this is because the panel has not loaded the data when it isn’t visible.
    panel needs to either have an option to be hidden OR an option to tell it to populate the data if hidden
    No, just no data
Thanks
