Can Grafana paginate at the datasource level instead of at the client level?
As in you limit the results you load from the datasource, and then run the request/query again with an offset when you need more results. Versus loading all the results of a request/query and then Grafana paginates them in your browser.
My specific issue is that I’m loading logs via the MySQL (hence this subcategory) datasource pointed at GreptimeDB. If I load time periods with more than a few thousand results, the queries take much too long to load, if they load at all. To fix this I’d like to use datasource side pagination.
I have done some searching on this, and I think the answer is no, but I want to double check.
Thanks in advance. ![]()
