Packagecloud.io grafana ubuntu repository empty
The https://packagecloud.io/grafana/stable/ubuntu repository is empty.
Steps to reproduce:
curl -s https://packagecloud.io/install/repositories/grafana/stable/script.deb.sh | sudo bash
it installs repositories:
deb https://packagecloud.io/grafana/stable/ubuntu/ xenial main
deb-src https://packagecloud.io/grafana/stable/ubuntu/ xenial main
but repository is empty:
root@telemetrie:~# strings /var/lib/apt/lists/packagecloud.io_grafana_stable_ubuntu_dists_xenial_InRelease
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA256
Origin: https://packagecloud.io/empty/deb/
Label: packagecloud_generic_empty_deb_index
Date: Thu, 24 Nov 2016 20:19:51 +0000
Suite: xenial
Codename: xenial
Version: 1
Components: main
Architectures: amd64 armel armhf i386 ia64 mips mipsel powerpc ppc64el s390 s390x sparc alpha avr32 hppa m32 m68k sh arm64
Description: This is a generic packagecloud.io empty deb index.
Acquire-By-Hash: yes
Regards
Please follow install docs guide, it lists the apt repo name
it is what i did, somewhere you have a doc which tells to use this:
but this command installs the wrong repository.
but don’t bother, i already have setup grafana, with debian jessie repository.
What was the correct repo? I am seeing this error after last update.
