Problems installing on Jessie from apt repository
I’ve a problem with a new install on Debian Jessie, as per the grafana debian installation docs. The apt repository instructions have me add the line:
deb https://packagecloud.io/grafana/stable/debian/ jessie main
But this isn’t working. I’m getting an empty Packages file downloaded. Let me demonstrate with wget:
geoffc@ogrady:~/tmp$ sudo apt-get update --print-uris | grep grafana
geoffc@ogrady:~/tmp$ wget https://packagecloud.io/grafana/stable/debian/dists/jessie/main/binary-i386/Packages.bz2
Resolving packagecloud.io (packagecloud.io)… 50.97.198.58, 2607:f0d0:2101:270::2
Connecting to packagecloud.io (packagecloud.io)|50.97.198.58|:443… connected.
HTTP request sent, awaiting response… 200 OK
Length: 14 [application/x-bzip2]
Saving to: ‘Packages.bz2’
Packages.bz2 100%[==========================>] 14 --.-KB/s in 0s
2017-05-17 09:54:37 (118 KB/s) - ‘Packages.bz2’ saved [14/14]
geoffc@ogrady:~/tmp$ ls -l Packages.bz2
-rw-r–r-- 1 geoffc geoffc 14 Sep 19 2016 Packages.bz2
geoffc@ogrady:~/tmp$ bunzip2 Packages.bz2
-rw-r–r-- 1 geoffc geoffc 0 Sep 19 2016 Packages
We only provide 64 bit builds
Fair enough. :frowning2:
