hi,
I am looking for a way to override the default options (remove panel name, make transparent) but i cannot seem to find it.
And is there a way to override the link component with a custom one (with more options)?
hi,
I don’t believe it’s possible right now. Closest I can find is onOptionsChange
and onFieldOptionsChange`, but neither lets you change the properties you mention.
Out of curiosity though, could you share some more details on your use case?
we have a panel that I pretty much a navbar, so we don’t want the title showing up on top of it.
and we need some more options for the links (file/ dashboard links, open in new-tab or not, tooltip, …)
