Grafana 8.2.6
Loki 2.5.0 -
I am running Loki and Tempo and I have a derivedField in my Grafana data sources config to link from my logs in Loki to my traces in Tempo. This is working but I would like to override the name of the button that shows up in Loki to say something more meaningful than “Tempo” -
This seems to be configurable because if I browse the Grafana UI and click on Data Sources → Loki, I can see this field called “URL Label”:
However, I am not sure how to set this via config in my data sources file and I cannot find an example in the documentation. -
My data sources config:
apiVersion: 1
datasources:
- name: Prometheus
type: prometheus
access: proxy
orgId: 1
url: http://prometheus:9090
basicAuth: false
isDefault: false
version: 1
editable: false
- name: Tempo
type: tempo
access: proxy
orgId: 1
url: http://tempo:3200
basicAuth: false
isDefault: false
version: 1
editable: true
apiVersion: 1
uid: tempo
jsonData:
httpMethod: GET
tracesToLogs:
datasourceUid: 'loki'
tags: ['job', 'instance', 'pod', 'namespace']
mappedTags: [{ key: 'service.name', value: 'service' }]
mapTagNamesEnabled: false
spanStartTimeShift: '1h'
spanEndTimeShift: '1h'
filterByTraceID: false
filterBySpanID: false
search:
hide: false
lokiSearch:
- name: Loki
type: loki
access: proxy
url: http://gateway:3100
uid: loki
editable: false
isDefault: true
jsonData:
derivedFields:
- datasourceUid: tempo
matcherRegex: .*\,\"TraceId\":\"(\w+)\"
url: '$${__value.raw}'
urlLabel: "View Trace"
httpHeaderName1: "X-Scope-OrgID"
secureJsonData:
httpHeaderValue1: "tenant1"
You can see there I tried using urlLabel: as the setting but that doesn’t work.
No errors but the link is still called “Tempo” -
I dug through the various online guides and couldn’t find how to set this setting… Hence this post.
