Hello Community,
I am trying to fill in all null values within a column (Proxmox Node), with another variable (Hostname). I managed to get close, replacing all null values with the text ${server}… Any help would be appreciated!
I am using Grafana 10.1.
Thank you in advance
Welcome @hand1308
Not seeing the null values nor the $server variable
Hey @yosiasz, I circled the variables in the photos.
That is a crazy amount of overrides
Please show us how you built server variable. Not sure you can use variables in override
I attached photos of my global variable. And yes you can use columns in overrides, I made the Online column a hyperlink to https://${Proxmox Node}.lan.
Do you have any Grafana documentation, which claim that variable can be used in override as you have used it?
IMHO this is not supported.
No idea if it’s supported, I just figured out the hyperlinks from googling…
