This is not working as expected:
First, the good behavior without the 2nd aliastSub():
sortByName(grep(aliasSub(divideSeriesLists(#B, #D),'^.*host=([^;)]+).*','$Summary; host=\1'),'average'))
produces two series labels:
* {count,min,average,median,percentile,max}; host=fsrvbt-ob-133
* {count,min,average,median,percentile,max}; host=p272
Adding the outer aliasSub() the results are not as expected:
aliasSub(sortByName(grep(aliasSub(divideSeriesLists(#B, #D),'^.*host=([^;)]+).*','$Summary; host=\1'),'average')),'^.* host=(.*)','\1 - average')
Produces the following labels:
* fsrvbt-ob-133
* p272
However the expected output is:
* fsrvbt-ob-133 - average
* p272 - average
No matter what the formatting string is, Grafana produces the same series labels, even:
aliasSub(sortByName(grep(aliasSub(divideSeriesLists(#B, #D),'^.*host=([^;)]+).*','$Summary; host=\1'),'average')),'^.* host=(.*)','f')
produces:
* fsrvbt-ob-133
* p272
Is there a way to work around this?
When I test this on https://regex101.com/ with inputs:
- regular expression:
^.* host=(.*) - test string:
{count,min,average,median,percentile,max}; host=fsrvbt-ob-133 - substitution:
\1 - average
I get the expected result:
I managed to work around it by removing any spaces in the first aliasSub() and matching on the curly brackets in the second:
aliasSub(grep(aliasSub(divideSeriesLists(#B, #D),'^.*host=([^;)]+).*','$Summary\1'),'average'),'^[^\}]+\}([^\{\}]+)','\1 - average')
