[OSS] How to configure grafana assistant via yaml provisioning
    • Image Version: 13.0.1-security-01
    • K8s Version: v1.33.4+k3s1
    • OS: Ubuntu 24.04
    • I want to provision the Grafana assistant plugin on startup without clickops.
    • Using the provisioning YAML.
  • What happened? The UI shows this error:
  • Something went wrong
    An unexpected error occurred. Please try again.
    • Successful provisioning. It works when I put the required values directly in the UI.
  • apiVersion: 1
    apps:
      - type: grafana-assistant-app
        # org_id: 1 # default
        # org_name: Main Org. # default
        disabled: false
        jsonData:
          backendUrl: https://assistant-prod-<region>.grafana.net/assistant
          isAccessTokenSet: true
          instanceId: ${GF_ASSISTANT_INSTANCE_ID}
          ossMode: true
        secureJsonData:
          accessToken: ${GF_ASSISTANT_ACCESS_TOKEN}
  • logger=plugin.grafana-assistant-app t=2026-05-28T06:30:07.550420742Z level=error msg="Plugin Request Completed" statusSource=plugin endpoint=callResource pluginVersion=2.0.15 status=error duration=8.520213ms error="invalid access token" pluginId=grafana-assistant-app
I figured it out. There were 2 issues with my config.
The token field should also include the instanceId, but didn’t.
When, Grafana converts the plugin config to json, the instanceId is converted to a number. Simply adding quotes to the Yaml won’t work
Here are the configs that worked for me (note that I am using kustomize)
  • Kubernetes secret that is added to grafana
apiVersion: v1
kind: Secret
metadata:
type: Opaque
stringData:
  GF_ASSISTANT_INSTANCE_ID: '''"<GF_ASSISTANT_INSTANCE_ID>"'''
  GF_ASSISTANT_ACCESS_TOKEN: "<GF_ASSISTANT_INSTANCE_ID>:<GF_ASSISTANT_ACCESS_TOKEN_RAW>"
The quoting method is required for use with kustomize. Inside the cluster it shows up like the below
GF_AUTH_GENERIC_OAUTH_CLIENT_ID: <GF_ASSISTANT_INSTANCE_ID_BASE_64_ENCODED>
GF_AUTH_GENERIC_OAUTH_CLIENT_ID: '"<GF_ASSISTANT_INSTANCE_ID_BASE_64_DECODED>"'
  • The plugin config
# filename: grafana-plugins-provision.yaml
apiVersion: 1
apps:
    disabled: false
    jsonData:
      instanceId: "${GF_ASSISTANT_INSTANCE_ID}"
      ossMode: true
    secureJsonData:
      accessToken: "${GF_ASSISTANT_ACCESS_TOKEN}"
Which I created as it’s own secret with secretGenerator
secretGenerator:
- name: grafana-plugins-provision
  files:
    - grafana-plugins-provision.yaml
  options:
    disableNameSuffixHash: true
And referenced it in my helm chart values
extraSecretMounts:
  - name: plugins-provision
    mountPath: /etc/grafana/provisioning/plugins/plugins_provision.yaml
    secretName: grafana-plugins-provision
    subPath: grafana-plugins-provision.yaml
    readOnly: true
  • This is how the environment shows up in grafana
grafana-xxx:/usr/share/grafana$ env | grep ASSISTANT
GF_ASSISTANT_INSTANCE_ID='"<GF_ASSISTANT_INSTANCE_ID>"'
GF_ASSISTANT_ACCESS_TOKEN=<GF_ASSISTANT_INSTANCE_ID>:<GF_ASSISTANT_ACCESS_TOKEN_RAW>
  • This is how it is rendered in json
# /api/plugins/grafana-assistant-app/settings
"jsonData": {
    "backendUrl": "https://assistant-prod-<region>.grafana.net/assistant",
    "instanceId": "'\"<GF_ASSISTANT_INSTANCE_ID>\"'",
    "isAccessTokenSet": true,
    "ossMode": true
"secureJsonFields": {
    "accessToken": true
This is how it shows up in the UI
Welcome @hayone1 great you figured it out the issue was Wrong accessToken format ->the accessToken in secureJsonData must be in the format instanceId:rawToken, not just the raw token alone so your secret value should be
GF_ASSISTANT_ACCESS_TOKEN : “your-instance-id:your-raw-access-token”
instanceId gets cast to a number by Grafana When Grafana parses the provisioning YAML it converts instanceId from a string to a number ,this breaks the plugin. The fix is to force it to stay a string by wrapping it in escaped quotes. the triple-quote trick is needed:
yaml
GF_ASSISTANT_INSTANCE_ID: ’ ’ ’ “your-instance-id” ’ ’ ’
Inside the cluster this renders as ’ “id” ’ ->the extra quotes survive YAML parsing and force Grafana to treat the value as a string, not a number.
isAccessTokenSet : true in jsonData ->setting this in the provisioning YAML does not validate or confirm the token. It only hides the input field in the UI. If your token is wrong or empty, you still get invalid access token - the flag just makes it harder to notice.
