Order of panels when viewing on mobile
Hi guys,
Is there a way to change the order of the panels for mobile view, without changing it on the PC?
I want the panels to be in certain order on mobile view and didn’t manage to do so.
Thanks
Hi @amichai
Based on some quick experimenting, I don’t think you can differentiate mobile views from PC views. But I can tell you that imrpoving the mobile experience is a priority. You might want to make a feature request as the a new mobile UX develops…
Also REALLY want this feature to be able to manually number/order the columns for mobile view.
I wonder if it would be easy enough to add it so that we can manually select the order (by assigning each panel a number) for mobile view?
Or, is this already a thing?
